regarding the clutch... at the bottom of the pedal stroke it hits a sensor. i took those two wires, cut and joined them. no biggy, and it is actually under the same location as the chime.
there should be a little black "L" shaped, spring loaded slider in the door of your car. when the door is shut the slider gets pushed closer to the inside of the car. if you push it so that it opens, such as the door being closed, you can remove the screw and pull the wire out of the back of it. then replace it back on the door. job done
only problem is your cab light wont automatically come on.
