Which Cams Are Better For Me?
Discussion in 'Engine Building' started by Civic98HB, Apr 21, 2003.
  1. Civic98HB
    Civic98HB Junior Member
    Which one is better for my car? B18C JDM 20k, supercharger and some other things.
    Or which one is closer to the regular honda cams?
    Type: Intake Lift: Intake Duration: Exhaust Lift: Exhaust Duration:
    Toda Spec A 11.6 mm 250 @ 1mm 11.2mm 240 @ 1mm
    Toda Spec B 12 mm 255 @ 1mm 12.5 mm 255 @ 1mm
    Toda Spec C 12.5 mm 255 @ 1mm 12.5 mm 255 @ 1mm
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    Toda cams are for NA applications.
    i've heard good things about web cams for supercharged vtec motors, check them out. or get stock GSR cams, or stock 99 si cams.
  3. E_SolSi
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i have a set of stock b16a1 cams with 40K on them. let me know if youre interested.
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    OEM R cams would work nicely............
    Milan
  6. B16
    yay area, CA
    you would need cam gears to kill some of the overlap then.
  7. pissedoffsol
  8. PROFILES2000
    PROFILES2000 Member
    OEM R cams are the highest duration cam i would run on a FI car.
    i would prefer to run stock honda cams that came in that head.
  9. JDMilan
    Boca Raton, FL
    You will be fine with R cams for FI, if thats too much then go with GSR cams........it shouldn't though
    Milan
