Which One?
Discussion in 'Integra' started by K-Money, Dec 31, 2006.
  1. K-Money
    K-Money New Member
    well as you can tell am i new to the forum and i was thinking of getting a new car soon which is a dd but is able to go fast when i want to. i was planning to buy an integra and i wasnt sure which model was the best. i was looking in the 95-98 range and i dont know if i should get the LS or GSR or whatever else there is. i heard that the LS is potentially faster but the GSR is faster then it as is. well thanks guys.
  2. hazzardboy95
    hazzardboy95 Hon-daaaa
    Pasadena, Md
    If you dont want to tear your ls apart to strap on a vtec head and everything that goes along with it shoot for the gsr. Stock is about 180hp and 130lbs of torque I think.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    or you could just buy the tyrpe r integra and be done with it
  4. hazzardboy95
    Pasadena, Md
    Or you can do that, if available. If you have the chance to get an itr go for it.
  5. K-Money
    K-Money New Member
    i was planning to put in some sort of turbo in it so which model would be better in that sense?
  6. AHHVTEC
    Alabama
  7. hazzardboy95
    Pasadena, Md
  8. K-Money
    K-Money New Member
    why is the ls model the best for me? i was just wondering. thanks for the responses.
  9. AHHVTEC
    Alabama
    lower compression and longer gears
  10. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    It's a misconception that the longer gears are better for a turbo not true.
    But the LS does have lower compression but with some tuning you can make
    the GSR motor with a turbo work NO PROBLEM.
  11. AHHVTEC
    Alabama
    well car guys are like doctors everybody has there on opinion
  12. myah
    myah Neu Impact Performance
    ks
    lower compression and the stock sleeves can handle more boost i wouldn't but turbo on a stock gsr cause chances are the first time you get on it it's gonna blow ls/vtec turbo thats a good setup but a fully built gsr would be better
  13. 801CRX
    801CRX Got Rice?
    UTAH
    Ls is the strongest stock B18 block in my opinion, and the low compression takes kindly to forced induction.
  14. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    where do u get this?? its hard enough keeping traction with an all motor car that has short gears. properly sized turbos shooting for max hp dont make power until 4k or so. so if you get from 4 k to redline in 4 secs you are only in your max hp for that short period of time. with longer gears you are able to stay in your peak power for a longer period of time thus making the car faster.
    so where is the misconception?
  15. K-Money
    K-Money New Member
    what does b18 stand for? ive seen it used before on this forum like a b18 or b16... thanks guys.
  16. hazzardboy95
    Pasadena, Md
    B is your engine code and the number stands for your displacement.
  17. myah
    ks
    b18 is your engine code or block code b16a would be a honda doch vtec motor or an si motor a b18c would be a gsr motor b18b is a ls block you get the picture now
  18. 801CRX
    801CRX Got Rice?
    UTAH
    B= series or engine code
    18= displacement is actually 1.798 or something like that.
    B= identifies which motor for instance B=Ls and C=Gsr
    And any number after these three id's its a USDM make.
    B18C5=USDM
    B18C=JDM
  19. AHHVTEC
    Alabama
    the 90-00 ls is 1834 displacement
  20. 801CRX
    801CRX Got Rice?
    UTAH
    Oh new to me thanks for the info.
