LifeSucks88
I was going to do a LS V-Tec but a got a killer deal on a B18c1 block today
$50.00.
I drop the block at the shop to have 0.022in milled off the deck height to make the same height as the b18a block and it being bored to 81.50mm
Parts list
B18A/B SRP Pistons 9.5:1 but with B18c1 head milled 0.008in makes it 10.27:1 Static Comp Ratio
b18A/B Brian Crower Econo Rod
Zero balanced B18a Crankshaft
ACL RACE SERIES Rod & Main Bearings
New ITR Oil Pump From Acura
Golden Eagle oil squiter plugs
ARP Head Studs
Update 10/21/2010
P72-1 head with
It's in the shop when i get it back i will post pic's.
ITR Cams
CROWER CHROMOLY RETAINERS
BLOX DUAL VALVE SPRINGS
Ferrea Flat Face Stainless Steel Velves
AME Tru Timing Gears 23-602 Blue
Parts list
ARP Head Studs
Update 10/21/2010
P72-1 head with
ITR Cams
