H22 Problem
  • Thread starter Thread starter jchrm80
  • Replies Replies 2
  • Views Views 987
jchrm80
Sorry to double post.
My H22A swapped eg hatch wont start. I went to leave for work and it started up fine and idled. I went to take off and the car just died and now it wont start. I checked over the engine bay to make sure nothing came lose or was leaking. Power comes on, there's fuel pressure it just wont turn over. I was told it may be the coil, Does anyone have any other ideas of what could be happening or what i could check? I did a spark test, and no spark. I grounded the spark plug to the block and cranked it over.
I was told it may be the coil, so I looked up a coil for a 1993 Prelude, and bought one thinking I had the right part to start trying to fix the problem. I'm not very knowlegable on h22 swaps and I wasnt sure if you kept the external coil when swapping the engine into an EG. Any help would be greatly appreciated.
Symptoms seem like the same ones I had on my D16Z6. What caused me to replace the coil was, with the power on, I got no spark, and with a test light it was extremely weak. I'm not to smart when it comes to the H22 or a Hatch, but I would make sure to use the coil that comes with the H22. -Gary
does the motor turn over wont start ? if so check for spark if theres not any it may be a bad dizzy, but if the motor does not turn over at all make sure you motor grounds are hooked up
