INJEN78
HS LEGEND
yesterday i installed a narrowband A/F gauge in my 91 civic..i ran the power wire from the power wire for the ecu,the ground to the ground wire for the ecu and the other wire to the o2 sensor wire(obd0) started the car up and it is dumping fuel,theres smoke coming out the exhaust and i can smell the gas in the exhaust..but im also now throwing codes for map sensor and injector,code 3 and code 16..
so my question is what could be wrong???the car ran fine right before i installed the gauge..
what would happen if my injector resistor box just quits working?
