if your not making it red hot it's not changing the properties (it will be non magnetic when it's reached this temperature). but if your not making it red hot it's not doing anything to break the corrosion anyway.
have no way to come up with money until the end of the month.OK. Erase from your mind everything you think you know and all of the options that you have explored.
There is a proper way to do this, and there is a proper tool for the job. Using this method will not damage your car in any way whatsoever and is actually recommended by Honda themselves.
Its called a breaker bar. Go borrow one, Check out auto zone's loan-a-tool program. Hit the local pawn shops. I know you said you don't have any money, but you should be able to pick up a nice one for $20-40. You should be able to come up with $40 somehow..
Just go do it, before you damage a $60 axle and end up having to buy a breaker bar later in life for something else anyway. Its just one of those tools you should have around.
yesis the axle still good? do you plan on putting the same axle back in the car when you're done?
dont have 30 bucks or a ride to walmart.shyte i have a black and decker grinder that came with a cutting wheel, got that shit for thirty bucks at wal mart.. go check out wal mart!
Don't you have a jack? Does the handle come off of the jack? If it does put the end of the jack handle over the handle of the socket wrench. That'll be more than enough leverage...
how is that a smartass thing to do?? oh wait i get it, get a nut off lolSorry, I don't have the patience to read through 90 posts about how you can't figure out how to get a nut off. You're just lucky I wasn't feeling like a smartass and post a link to some porn.
well, apparently you cant figure out how to get it off either.
cuz that didnt work.
I still don't understand how this is soo hard to do. Ok, you don't have the money for tools. You don't have neighbors? You can't borrow tools? Do you have any big box end wrenchs? If so, put the biggest box end you have over the end of your ratchet. It'll give you leverage, I do it quite often.
