cluster swap
  • Thread starter Thread starter crx8787
  • Replies Replies 14
  • Views Views 8K
crx8787
cluster swap HELP
Would the 90 to 91 civic WAGON cluster fit in a 90 civic hatch std??
cant find a pic, but pretty sure the shape is the same, i want to cause the cluster i got has no tach and i dont want to mess up my dash putting a autometer bull**** on. just want to know if plugs are the same
CRX DX's have tachometers, not sure about the HFs.
I actually have a DX one but it's at my cousin's house(about 80mi away)
Also, if you wanted to, you could put just about any cluster in your car.
Here's mine(94 GSR): http://i27.photobucket.com/albums/c164/K2e2vin/100_2460.jpg
The Accord ones seem like it would work better though; too bad I threw mine away.
sorry for the threadjack, but how did you do that?
my 90 came with the GSR cluster but my speedo never worked.
and I am sure the OP can use an Si cluster and the tach will work, so the wagon one should, I would just try it.
Pretty much just retrofit/wire in the GSR plugs(I actually used a set from an LS since the cluster didn't come with them). You have to swap over a electronic VSS and wire it in. The 88-91's have it built into the cluster.
I believe the wagovan cluster will work just fine.
and like kevin said you can use a different newer cluster as well. just make sure you wire up the electronic vehicle speed sensor. common ones would be the integra ls/gsr/type r cluster, crv cluster, and the 99-00 Civic Si cluster. i have a 94 ls in mine.
got a pic of my cluster, what is that box with the blue plug??
mine looks like that as well everything but the gas gauge and speedo work in mine but I dont know what plugs into the blue. BTW i"m gettn a 17 code VSS so how do I wire it in as stated above.
that blue plug is for cruise control i believe. And the question about the 90-91 wagon cluster, yes it will work. I have a 90 wagon and have switched between the hatch and 4 door clusters in my wagon.
