si cluster
  • Thread starter Thread starter chadcharb
  • Replies Replies 17
  • Views Views 4K
chadcharb
Well-Known Member
VIP
im lookin at a si cluster on ebay cause my car doesnt have a tach now, just curious how hard will this be since i dont already dont have a tach
Make sure you get a 90-91 cluster because 88-89 will NOT fit in a 90-91 car and vise-versa.
Other than that it bolts in perfectly and everything works like stock.
and also everything that i see is for 88-91. nothing shows for just 90-91?
No wiring is needed, it goes in like stock.
A way to tell between 88-89 and 90-91 is the 88-89 clusters are more flat on top and the 90-91 clusters are more rounded on top.
88-89:
90-91:
Just wondering... :ph34r:
If you got gauges with kmh instead of mph could you take them apart and put your speedo into the gauges with the tach?
you mean take the kmh overlay out and replace it with the mph? yea its the same size and such just labeled diff...gotta be careful not to break the needle tho
I was just wondering. Cause every cluster i find cheap is KM/h and i did it in my accords so i wanted to know if the kmh and mph would be the same size to swap em out.
I guess ill but the next cluster i see cheap and use my mph gauge.
Thanks and +rep if i can.
soooo your wanting to swap the guts of the cluster? theyre both the same...just one is labeled mph and the other is kmh. just switch out the guage face that says...mph
I don't like messing with the needles... lol
Why not just buy an aftermarket tach and install that? You can put it between the shifter and the coin holder in the EF's and nobody will notice it. Would cost about the same.
I hate aftermarket gauges... I could get one for free but id rather have it in dash.
Thanks for the idea though.
