1.5 gets 10mpg
boostfreak 417
ok so my buddy has got a civic with a 1.5 in it and its been getting only 10 mpg out of the many things it could be what do you recomend, i was just wondering if anyone has had this problem
not possible............ Did hummer make a 1.5 L?
thats what i was telling him i used to have a dpfi in my std civic till i swapped it to a d16z6 obd1. it got amazing gas mileage, aight il go check this piece!
sounds like that car needs a better driver
ways to improve gas mileage:
stop reving at the cars next to you at red lights
shift out of first every now and then
dude i had a 89 hatch 4 speed it had a header and full catback and i was only getting 200 miles per tank and i didnt no what was wrong with it
did he install an amp or something? drilled in and put a hole in the tank
funny you say that i was puting a fuel pump in a DA one time and couldnt get the tank to come down for nothing and when best buy installed the amp they use really long self tappers and went right in to the tank
Fyuck BB... Tey can choke on bawls and die
that's why i do all my own work.
Certainly a tune up. Is the check engine light on? Thick black suit around the tail pipe and even up onto the rear bumper?
I had a pontiac back in high school (4 cylinder) that got 8 miles to the gallon.. There was a wire grounding out in the injector wiring, it had worn through the harness and was grounding to the head.. the injectors were on full blast no matter what.
