GoTeamVentures2000si
So at around what id say would be 7-10% throttle my gas peddle is kinda stiff and it takes some pressure to push it down which causes an annoying jerk. Im not sure if it would be just a dirty throttle body, or the throttle cable is too tight. Im gonna check the throttle body tomorrow but im worried that may not be it. is there anything else it could be?
Also I have motor mounts on the car which cause it to shake just alittle when idling but sometimes i notice a slightly different shake.. I could just be being paranoid and its just the mounts, but i was thinking that if theres a problem with the throttle cable being too tight when im idling my engine might not being breathing enough.
Any ideas would be appriciated.
