D-Series headers, CRX lights, Nearly new CRX Battery, other D-series parts!
  • Thread starter Thread starter Dasfinc
  • Replies Replies 13
  • Views Views 2K
Dasfinc
I have a TON o stuff floating around my shed right now that I need to get rid of:I have:
a BRAND NEW D-Series megan racing 4 into 1 header, $100
a USED no-name D-Series 4/2/1 Header, $SOLD
a set of BRAND NEW 88-91 CRX Clear Corners
a set of BRAND NEW clear lower front CRX turn signals (one has a broken clip IIRC) $10
a set of used OEM corner turn signals off an 88 CRX (still in good condition) $10
a 92-95 Civic CX transmission with a bad main bearing $30, shifted smooth when pulled (VERY easy fix, GREAT gasmileage transmission)
I have a 1 year old Civic CRX SI battery (high end Exide) $30
I have a 94-01 integra Rear T-bracket for AUTOMATIC cars (will not work on manual ones) $15
I have a 92-95 D-Series civic rear T-bracket $15
a 1992 D15B8 (8 valve) head, in perfect working order, pulled for a mini-me swap with 92K on it. $40
a 94 D15B7 head with no cam, and a broken bolt in one of the cam holder spots *springs/retainers can still be used, or can be used for porting if you EZ out the one bolt *again, easy fix* $30
a 94 D15B7 intake manifold, mostly bare $15
92-95 D-series NON vtec valve covers *I think I have 2, they both need a repaint, but would be perfect for it* $15 each.
used OBD1 D-series Ignition coil, pulled for Accel HEI coil upgrade, $20
I will post pictures as soon as I can, if you have a question about something, PM me, or email me (dasfinc@hotmail.com) and I can get you a picture sooner.
I also have a pair of OBD1 D-series engine harness's, both have been cut *one is missing its O2 wiring and a single plug, the other is complete from a 92 CX, and has a few splices, nothing missing. they both have plenty of plugs still on them for V-tec solenoids, and other uses, $50 shipped for the pair
Prices unless noted do not include shipping.
Pics of the OEM corner turn signals off an 88 CRX
I know thread is old but do you have the d15b7 head if so i need it like two weeks ago. lol
