LUDERACERGIRL
Hey everyone, I'm new here and tried the search but it didn't quite answer what I needed.
I have a 91 civic hatch si with a d16a6 mini swap on it already with rpm switch and stock ecu. This has a bad body.
The good shell I have it a 92 hatch, so I'd like to make one good car out of the 2.
Does anyone know if:
- The motor will fit in stock mounts?
- Axles fit?
- How much wiring will need to be done?
I can see that ones hydraulic and other it cable clutch, but is the swap even worth the hassle.
Thanks
- Axles fit?
Thanks
