I've got a Mini-me project with a d16z6 head going on a d16a6 block. I want to rebuild while it's out of the car, and plan on going with one of the kits, as they are much cheaper than piecing together everything needed. So my question is, will a kit designed for the z6 work on the a6? water pump/oil pump mounting, timing belt, etc? Also are the bearings the same size in both engines?
