jibrilsauto
I meant it looks like the brackets are not the same. Also what alternator and what power steering should I use? will I need to get prelude belts or can I keep the same ones?
When I did my swap, I used the PS pump from the H22, and the alternator as well. I had to have a custom line made for the PS; I took both lines to a place in houston, and I think they did it for 35 or 40 bucks. it's been a while, so I don't remember for sure. For the AC, I used the accord compressor, the accord bracket, and a 5-rib pulley from a 98 accord.I meant it looks like the brackets are not the same. Also what alternator and what power steering should I use? will I need to get prelude belts or can I keep the same ones?
