Its a b16, but it has aem cam gears. That does help a lot though thanx.one ur cam should be a place to hold the cam itself w a wrench then u can break the cam gear bolt loose.. didnt catch what engine or anything, this is how i did it on my b18... if not put leave the timing belt on, and put car in gear, pull e brake. and break it loose that way.... hope this helps
