Welds look great for DIY. Throw some high temp black paint on there any nobody will be able to tell
i think ill go with this idea, i need something pretty durable though (kinda gets beat around a bit when i install it) any suggestions?
yeah im gonna go with rustoleum i think, powdercoating this would be a waste lol
i had my charge piping painted in that textured stuff for a while, it is actually really durable. im just not sure how i feel about the textured look lol.. itll probably be gloss black with a few thick coats of clear.That's a good plan. Wrap the thing with rags when you put them into place so you don't scratch it. Some of the textured finish paint they make would look pretty sweet too.
hahahaha! ballin!bump that .
dip them in chrome!
looks good man!
nope, i bought an OEM gasket, installed it, and tightened the pan bolts to spec and called it good.Have you had any issues with that oil pan? I could never get mine to not leak around the gasket and finally ditched it.
honda oil pans are pretty much paper thin which sucks... you HAVE to use an OEM gasket on them. on my hondas all the non-OEM gaskets started leaking shortly after i put them on.
 when I went to put a fitting in my stock pan i had all sorts of trouble trying to weld the new fitting in. ended up brazing it instead, then shortly after ditched that for the moroso.
