Unless I'm missing something, that doesn't change anything. E85 has it's limits too. Yes, it will run better with higher static compression ratio's with any given setup than non-ethanol enhanced fuel.Or.... Run E85 and enjoy high boost + high compression. WIN![]()
Did I miss something? (It's happened before) I'm with you on running E85 on a blown engine for the street for sure.![]()
E85 has a knock index of 105 octane, although it behaves more like 112 octane fuel. And is cheaper by the gallon than 87 octane.How does that work?
Yes of course E85 has its limits too. Typically above 700hp you start to run into issues with variances of different batches of E85 having different knock ratings. In the Evo world people are building 10:1 CR motors and running 30 psi of boost on stock framed (not stock turbos though) turbos.Unless I'm missing something, that doesn't change anything. E85 has it's limits too. Yes, it will run better with higher static compression ratio's with any given setup than non-ethanol enhanced fuel.
But, within the constraints of E85, the same principle applies with regard to manifold boost pressure and static compression ratio. Lower static compression ratio's will support higher manifold boost pressure without detonation.
Depends upon how much boost. What are you going to use for the ECU? I'm guessing you are going to have it tuned so it's correctly setup for the blower.O jeez haha so running 10 to 1 on e85 won't cause issues with det.?
^ Thank you sir.
So, my DOHC ZC which is now at 10:1 static should work well at 10.5:1 static? Running stock cams and is normally aspirated with a 61mm TB.
