nothing but problems.
  • Thread starter Thread starter danny95ex
  • Replies Replies 5
  • Views Views 1K
danny95ex
Have a stock b20b trying to get the ac installed has been nothing but problems. It her the wrong bracket or the wrong compressor I don't know what to do???
yeah b20's ac doesn't work right, you need to get an integra ls bracket and use the civic ac compressor if you still have it. the b20 actually has a larger diameter crank pulley than the ls does, so you'll actually be doing a bit of over-driving the components and belts will be not the perfect fit.
I got a ls bracket it does not line up with the stock compressor
right, you'll need to use the civic compressor, not the teg
Sounds like someone may have given you the wrong compressor, normaly this is a quick simple swap, like said before the belts dont fit perfect but there damn near close, or someone gave you the wrong bracket, they are similar
