dilbeckskate
infamous
Ok now cannon muffler has to go, what would you guys put on it far as muffler/tip
you will need to redo the intake manifold as the SOHC intake won't bolt onto the DOHC ZC headbought a View attachment 24948 dohc zc today for $350 needs rings, going to put high compression pistons and rods in it and use it as my swap candidate for the 79first person on this coast doing a dual cam zc swap in a first gen civic, still going to run the same motorcycle carb setup
Ive got a dual cam intake and im cutting it for carbs, that pic is of a browntop in a 1gyou will need to redo the intake manifold as the SOHC intake won't bolt onto the DOHC ZC head
you do need some way to control the ignition timing - we tried using the 86-87 Integra D16A1 vacuum advance distributor but it didn't work very well - couldn't get enough advanceI was thinking correct me if im wrong but I need to be running a vac advance distributor with a carb setup ?
What would you reccomend and I appreciate your inputyou do need some way to control the ignition timing - we tried using the 86-87 Integra D16A1 vacuum advance distributor but it didn't work very well - couldn't get enough advance
