russianswty
Okay so I've dropped a ls/vtec into a 89 crx Si using a obd1 setup. So I've got the
obd0-1 ecu jumper, p28 ecu and all the sensors. Yes I'm using the stock harness
with the addition of the extras that I need. And the motor is not firing up.
So I've narrowed it down to one thing, no spark.
I have gone through all my wiring to check it and it looks fine.
The coil is receiving the 12+ volts
The entire ignition system has been replaced with new stuff
that includes the entire new distributor, cap, rotor, wires, plugs
The battery has juice. The motor is cranking (not seized) so yes the rotor
is turning.
Ive even tried connecting back my pm6 Si ecu and still no spark. Whats could
be my problem?
is turning.
be my problem?
WTF? dude your telling us that you only have 1 white wire hooked up?? your supposed to hook up everything to its color. the fat wire goes to the yellow/grn. wire. I dont understand how the car is running at all. If it is you WILL throw a code. there should be ABSOLUTELY NO extra wires
