VITARAS!!!
in for updates.
cool build but do you really think that you can just put methonol in your tank and run it do you know the amount of work that has to be done to the fuel system to run that stuff. and those 550s will never be big enuff for that power goal unless you plan on runing about 85psi of fuel presure. and the will never be big enuff to make that much power on methonol.
you will never be able to run a welded diff on the street and you might as well stick to racing turtles if you are roing to use a HF trans but other than that it is a cool build
