Quoted post[/post]]
hey wus up i'm jose Ima new in the forum I need to know if there is an engine that can be swaped to my 2001 honda accord 2.3l vtec, I red on the internet about a prelude engine but I can't find engine numbers nor other info related. I need help plz
thank you
Quoted post[/post]]
thank you
Quoted post[/post]]
H22A4 is probably the engine you want to look for. Especially if you are in california due to the smog laws. if you know what you are doing you can change from an OBD2 to OBD1 in just about every other state, you just have to find an H22. A word of warning. If you get the H22A4, the ECU has an immobilizer on it, and it will need to be reprogrammed at a honda dealer.
hmotoronline.com sells full swaps i would go with a jdm motor if i was you..if you dont care about being smog legal. theres ways around it. the type s jdm motor would be the best one to get because of the wiring hasle being that its already obd 2 and the fact that thats the type r of H series motors..it has a stock crank hp of 220 and torque of 163. then get a motor mount kit if you need one for that car ..that engine comes stock with LSD. and you might be able to use your stock wire harness from your accord if its vtec.Quoted post[/post]]
thank you
