81 civic no spark
  • Thread starter Thread starter JERONIMO
  • Replies Replies 3
  • Views Views 762
JERONIMO
91 civic no spark
I have a 91 civic hatch. one day i was driving the car and it just died, now it just cranks over and over. I found that there is no spark, not sure if its the distributor or the ecu. When the key is in the on position the ecu light flashes 1 then 10 not sure if this could be the problem...Anyone else have this happen?
code 1 is o2 sensor. code 10 is intake air temp. The cause would be in distributor because this has happened to me. Remove dizzy cap. Check for a loose screw. This would be the problem, this screw holds rotor in place for current to be on in the ignition turn on car power. Use loctite for permanent fit.;)
thats not necessarily true, my cousins 90 rex w/ d16z6 had a loose screw rattling inside of the cap.. no check engine light, and no starting issues.
