88 CRX si B17a engine harness swap question
  • Thread starter Thread starter bjude1
  • Replies Replies 3
bjude1
I'm am contemplating using the B17a harness in my '88 CRX si. I have swaped in a D16a8 for the factory engine and rewired the dist. I know that the CRX engine harness is diffrent but I am wondering if I can use the plug "car side" from the DA "wrecked" and re-pin the car side of the CRX to work with the B plug/harness. The old CRX harness is discolored and brittle. I am figuring I will have to run a few wires from the ECU to the shock tower harness. Has anyone gone in this direction be for?
Its way more work than its worth, to swap the plugs and re-pin everything is a lot more tedious and time consuming than just adding the few wires for the VTEC components.
