90 CRX Swap Help
  • Thread starter Thread starter FKI_Raider
  • Views Views 844
FKI_Raider
Hi Guys I have a 90 crx MPFI with a blown motor with no head or intake and my friend gave me a 89 Crx that is DPI i put the motor in and the wiring harrness is diffrent what do i have to do to make this motor run i have no extra cash to spend thx for the help
I moved this out of the multimedia forum for you. The wiring harness is going to be different. If you want to do this and I don't know why you would you need his old wire harness and ecu. You would then have to figure out the wiring using the mpfi to dpfi swap info but do the wiring backwards. Just save up and get the mpfi intake and distributor it will save you a huge headache.
MPFI Swap use the mpfi harness, reverse what this tells you to do, and use the dpfi ecu, but sticking with mpfi is MUCH better
