94 Hb With Gsr Engine Need Help!
  • Thread starter Thread starter hb9406
  • Replies Replies 1
  • Views Views 733
hb9406
eg b18c1
I Have A 94 Civic Hb That Had A D15, I Now Have A Obd2 Gsr Engine In The Car. My Question I If I Can Run That Engine With An Obd1 P72 Ecu Of Do I Need 2 Convert My Harness 2 An Obd2 An Run With An Obd2 Ecu?:(
you can run it off an obd1 ecu. it will plug right into your car.
you will also need to re-wire the IAB on the intake manifold. There is an article on this in the Swap Articles forum.
the plugs on the motor will be different through.
Easy fix-- get obd1 parts for the alternator, distributor, and injectors
harder fix, less cost - swap plugs and re-wire to make the connections.
