Age old question
  • Thread starter Thread starter Airgetcha
  • Replies Replies 6
  • Views Views 940
Airgetcha
set up: B16A CRX/4 into 1, 2 bung headers.
Question: can I use the 4 into 2 into 1 crx headers for sale on ebay with my B16A?
ok, now I am confused!
Here's a little more info. Currently, my 4 into 1 header hangs to low. The lower two tubes are smashed to hell. The car still runs ok, but I'm sure I am losing some performance not to mention some sort of unequal backpressure from cylinder to cylinder. Not good! What is the solution HONDA GODS??????
Get a 4-2-1 header for a b16..
If you buy the "crx" headers from ebay you will get headers that fit a d-series. They will not bolt up to your motor.
I think you should be looking for b16 Del Sol headers..
Can anyone back that up? I'm not certain.....
.........the reason the header is low is because of your mounts..
as long as its for a b series youll be fine
..i have a cheap 4-1 focuz header and its a little low....but a 4-2-1 i think it will sit just as low........
and a b series header wont fit a d series....
