Air Intakes
milk215
Can someone explain the difference between a short RAM intake and the regular long one? Which one is better?
There are two types. Short ram and Cold Air Intake (CAI)
CAIs are better because they pull in cooler air from outside the engine compartment. Depending on the application you can also get a bid of a ram air effect going down the highway. The only problem with them is that they can allow water into the engine if you drive in a flooded area or really heavy rain.
Hope that helps
Sean
the filter must be submerged entirely under water,,
short ram gives a tad better throttle response but pulls in warmer air
vice versus.
vice versus.
comptech icebox :thumbsup:
throttle response of a short ram
power gains of a cold air
no worry of sucking up water
QUIET
but its not cheap
and its somewhat of a bitch to install (compared to any other intake)
:werd: the ice box is best. Gives you benefit of a cold air source from the cai, mid-high gains from the short ram, doesnt suck in water, really quiet for sleeper, and loud when you take off the top cap. Its the best of both worlds.
* i bought a "type r" version of it. I am pretty sure it is generic. i got it for 75 with a filter, kinda pricey but i think its worth it. had to take off bumper to install but well worth it if you live in CA. You can't really hear the moded intake with cap on.
