B-series Swap Question
  • Thread starter Thread starter uhh45
  • Views Views 948
uhh45
I have a 97 civic coupe dx, w/b16A2 swap from 2000 SI, w/ 97 gsr ecu well the acura and the hondas have a different voltage from the fuel tank pressure sensor so I keep getting a code and engine light, well I then bought an ecu for a 2000 SI. My wiring harness is from a97 ex w/vtec everything on my car is OBD II but the si ecu doesn't fit the harness. ANy suggestions? I need this problem fixed ASAP because i need to get my car smogged. Please guys help help and help me some more!! Also I have a complete B-series turbo set up w/ t3 garrett, intercooler, I/C piping, nos in line fuel pump, mits BOV, vortech FMU, missing link for map sensor, b-series manifold, steel braidd line for oil feed, 3in down pipe, apexi indiglo boost gauge, auto meter air/fuel gauge, delta wastegate, manual boost controller all for $1300 + shipping, no shaft play
99-00 si OBD IIb 97 civic DX OBD II. :( different plugs for the ECU.
Top to bottom
OBD IIb (left 3 plugs used)
OBD II ECU
OBD I ECU
OBD 0 (JDM PR3 and PWO)
