Hi, my motor is a freshly rebuild 1st gen. jdm B16a i burn oil alittle. I did an oil change, and immediately after i crank it to let the oil set in and recheck the level. it starts but sounded like a "WRX" which to me is a misfire. spark and fuel are all present. i pulled the spark plugs one at a time, while it was running to see if anything changes, all them make the idle change except cyl. 2. so i figure maybe the fuel injector is not good. i swapped injectors from 1 and 2. problem stayed on cyl.2. so my next approach was to check the valve lash? maybe it was to tight or loose. it was kinda loose so i re-adjusted it (intake .007 and exhaust .008)now no start at all. im gonna re-adjust again later today to see if that helps. either way adjusting the valves on the misfiring cyl. only should either make it better or worse but still start if im not mistaken? next step after is to do a compression test.
if you have any idea's or suggestions please let me know.
***please no stupid comments that arent gonna help***
