B16a1 IAC Valve replacement
ebisu8
Does anyone know if or what Idle Air control Valve I can put on my JDM B16a1. Mine is no good and I need to replace it so I was wondering if I could get one off of a 90-93 Integra or some other car I can find in the junkyard??? :( Thanks any help would be greatly appreciated
90-93 Integra wont work. Only 1 bolt lines up. I believe you order one from a 97 Del Sol VTEC or a 99-00 Si. Sorry for the bad news.
Brian
i know the d16z6 ones are interchangeable with your setup. i thought mine was bad(b16a also) so i swapped the one over from my GF's 94 civic ex and it worked/fit perfectly.
Great info man. Thanks, Ill tellmy friend who's having problems with his IAC about this.
