efcivic4dr
I have a b18a1 in my 91 4dr. Its throwing code for injectors (16). Before it was for fuel system supply (43). When you turn the car on it sounds like a Subaru and it revs out at 3000rpm. When you give it gas it just BLOWS white smoke and sprays gas. Its like the gas is just straight blow by. Sometimes at the downpipe flange it will blow a gas/oil mixture from there. but its not loosing much oil its just burning it. So the car is running extremely rich. Like i said, i messed with the fuel system and that code is gone. I didnt have an extra set of b18 injectors but i used d16a6 which are the same ones. The only thing i havnt changed is the resistor box. Can that be the cause since that is part of the injectors?
any help will be great thanks
-Carl-
-Carl-
