B18A1 into 88 si
  • Thread starter Thread starter JODYG35950
  • Replies Replies 1
JODYG35950
What's up guys, need help please.
I put a B18A1 in and used my si harness on the motor. Everything plugs up except I have no IAC. Where do I need to wire this to on the ecu. Also, are there any other wiring conversions I need to do for the stock harness with new ecu. I couldn't find a thred on this, if there is one give me a link or direct me to the right direction. Please someone help me with this.
The ecu is actually giving the EAVC code.
found out the iac plug was on the knock sensor. I changed it and extended the wires to work, now were do I wire the knock sensor to. Where can I find a pr4 pinout?
