b18b1 fully built need help on cam setting
  • Thread starter Thread starter cage518
  • Replies Replies 3
cage518
you guys have any suggestions i need to know what my best option would be maybe +2 degrees intake -2 degrees exhaust? i dunno, i can't get it tuned the place around here they are full for like 3 months
going to need a lot more info than that
for starters:
what cams
what pistons
what compression
stage 2 cams
probe forged high compression pistons
not realy sure on compression yet but its around gsr territory
the motor was completely built block up
i have the whole intake system upgraded and header back exhaust
upgraded spark, i went with the gsr ngk iridium they run 1 point cooler than the one for the ls and i got the obx-r 10.3 race wires
i haven't remapped the ecu yet but i have the spoon chip for it
whatever you do, DON'T PUT THAT CHIP IN. get the car properly tuned, or run the stock ls ecu till then.
