Citizen_Insane
I can't get the ball joint to come off my suspension so I can pull the axles.
Im assuming that you remove it by pulling the screw attatched to the ball part of the joint out of the hole in the LCA. I tried using a pickle fork and it won't budge and theres nothing for a crowbar to get ahold of. PLEASE HELP!!?!?!?!
\/ brake disk
_
||____
||.......| < Ball joint cup
||____| ball joint
|| |__|<---__________
|||__________LCA___.
||...|| < The bolt attactched to the ball part of joint
I am trying to sepparate the ball joint from the LCA where the "<---" is. This is correct is it not?
Again....PLEASE HELP!!!!
thanks - Kai
\/ brake disk
_
||____
||____| ball joint
|| |__|<---__________
|||__________LCA___.
thanks - Kai
