Basic wiring ?'s
  • Thread starter Thread starter legutki
  • Views Views 903
legutki
When adding plugs that are 2-3 wires how to you make into 1 wire that plugs into the ECU pin? Do U just soder them all together and make into 1 wire? Whats the best way to soder 2 wires? just twist and soder and then use heat shrink?
thanks
NO!
clarify what you are trying to do...
each wire from each particular sensor has a purpose whether it is a ground wire, power wire or the signal wire.
what sensor are you trying to wire up and to what ECU? in what chassis for what engine?
Ok im trying to put a hf motor in a 90 std. im doing a mpfi converion using the std harness. the hf motor has a egr valve lift sensor (for the egr valve) with 3 wires coming out of the plug. how do i hook that up to work properly?
