I'm setting up my guest bedroom tv with a firestick to stream netflix/prime/etc. The house came pre-set up with in-wall wiring in this little nook next to the closet. I threw an adjustable arm mount on it to allow the tv to come out of the hole a bit. But, i had wiring issues as we can see:
The tv usb ports are not powerful enough to power the firestick (it complains and wants to be plugged in to the wall).
The wall is pre-built in with a single power port hidden behind the tv and is recessed. The tv has an l-shaped power plug that won't fit int he recessed outlet and since there's only 1 outlet i need a splitter anyway.
This means the extension cord needs to be a flat plug or it won't fit and must stick out a bit. The tv is on an 'arm' swivel/adjustable mount, so it doesn't need to go flat and is too 'far' away from the bed when it's pushed back anyway so i don't think an inch or two of an adapter sticking out will be an issue.
So, i'm thinking,
move the tripplite protection strip to the floor.
get a 1' cable from the strip into the in-wall outlet behind the console table to bring the power up to the mount female recessed unit.
plug in a short 6" splitter cable for the 2 outlets needed, 1 for the tv itself and 1 for the fire stick.
something like this would do:
Amazon product
but, why bother with the AC to usb adapter? do they make a cable splitter like above where one lead is a usb and the other is regular ac?
Another option I just thought of is using the existing run of the hdmi cables that are in-wall already.
i could plug the firestick in down below to the low end of the hdmi run and hide it behind the table.
it would just dangle there on the floor i guess but wouldn't need a power run up any more.
I would still need an ac adapter power cord as the tv as an L-shaped plug and won't fit in that recessed outlet, so the first option is probably best.
Thoughts?
So, i'm thinking,
Amazon product
Thoughts?
