Cable To Hydro
does anyone on here know if there is a kit out there to convert a cable tranny to hydro? if not, its not possible to just bolt up a 95 ls tranny(hydro) up to a 1990 ls motor? the 90 ls motor has a cable tranny?
thanks
Last time I checked HA Sport had a kit in development, give them a call and see if it is finished.
i think that a 90 ls motor was a dseries and the 95 is a b series if that is the case then no you can not bolt up the tranny you might be able to find one that is from another d series if that is the case
No, the 90 Integra had a B18A1.
You will need to get the clutch and flywheel from a 92+ B series to make that tranny work.
sorry im not to smart with this stuff, so LSVTEC, what tranny are you talking about? are you saying it WILL bolt up, as long as i get a clutch and flywheel for a 92- up?
what was the name? its HA Sport, not Has Port?
thanks man, you are saving me :worthy:
Yes, the tranny will bolt up if you get a clutch/pressure plate/flywheel from a 92+ B series.
www.hasport.com but they do not update their site all that often. Give them a call.
If this is going into a car that already has a hydro tranny, you won't need the HA Sport kit.
i got a 99 si tranny short gear ratio for sale if your interested...should bolt into the b18 just fine
