Can i run a d16y8 with Obd0
89cmutr
Scenario-
16y8 head(aem adj cam gear)
D15b2 block
Mpfi swap into dx(obdo)
90si intke mani
90si trans
pm6 ecu
Will this work? If so is there anything i am missing?
:worthy:
Originally posted by Calesta@Jul 14 2005, 10:35 PM
You need something to activate VTEC, and you'll probably want to chip the PM6 to a P28 fuel map.
[post=526488]Quoted post[/post]​
:yes: use turboedit to activate vtec through the a/c switch on a chipped pm6. Search PGMFi.org. Ask Jason Parker, or Xenocron, I'm sure there are more, those are the only two guys I personally have chatted with though.
