can sombody please help
  • Thread starter Thread starter 93gsintegra
  • Views Views 750
well i have been fighting with this car for a week now...it died on me so i put in a new distributor and it runs...kinda... it sounds like it is way out of time.... i checked the cam gears and firing order and all looks good but it runs like it is way out???? any sudgestions?? i am about to just put in a b20.
just get the b20 if ya got the doe.
The things you need to check are spark, fuel and air.
First thing I would do it check the wires and plugs, make sure each is getting adequate spark.
Then go after the fuel, check the injectors, if they're dirty clean them.
The make sure nothing in the intake is clogged as well as the exhaust not being clogged up either.
If your getting all of the above, then do a compression test (check it no matter what), if its below 150 or 10% difference you'd be better off with a new engine.
