Ignitor in the distributor, would be my first thought if its not firing. I had a car a month ago, the owner had siminlar problems, they replaced the main relay and thought they had fixed it. It started because the car had sat. as soon as it ran for a bit it cut off again. We replaced the distributor and no problems since. A main relay pronlem will in most cases prevent the car from starting. This happens when they get old and the solder joints inside them crack and break the connections going through them.
if the ignitor was bad would i still have spark at the plugs?
i tried just starting it just to see it must not be the alternator
it makes that ah ah ah ah ah type sound when you try to start it not the tic sound when the battery is dead
