Han_solo1982
SOHC Pocket Rocket
This is my 1st heart transplant (engine swap) i am going from the standard 1998 civic coupe D16Y7 Engine (with the big end knocking - Ouch -) to a 1995 civic Esi Hatch D16Z6 VTEC. I have the engine, gear box, both axles, the Full car wiring Loom, and ECU. I have seen OBD2 - OBD1 converters BUT i am unsure if this will allow for the Vtec to work on the engine and keep the coupe standard wire harness. I need some advice should i just change the whole wire loom out or will the converter harness work to get the engines Vtec working properly???? any advice you can give on this matter would be grand cheers.. John
