cr vtec problems
  • Thread starter Thread starter acura1
acura1
love my DA
is possible to run a none chipped pr3 ecu on b16a head on b20 block because it seems im not getting enough fuel could that be why
The PR3 should work well enough, assuming you're running everything as OBD0. Obviously you'll want to look into some type of tuning solution specific to your setup, but it should function okay for now...
well im not sure if its my fuel pump or somthing else because i changed tps,idle air,fuel filter, fuel injectors,and when ever i get about 3000 it bogs like im not getting enough fuel but if u spray starting fluid in intake it clears what could that be
Do you have any check engine lights on? It sounds like the car is in "limp mode"...
yeah when i got the b20 a year ago the check engine light came on i got everything but my distributor in to do obd1 im hoping changing everything will help
