CRX DX 1.5 new Trans.
  • Thread starter Thread starter CRseX84
  • Replies Replies 11
  • Views Views 842
CRseX84
k so i droped my DX transmission, i know the SI trans. is set up for to be quicker, well i obvously g2 swap the trans out will the SI trans bolt right up and be streight with linkage??
:english:
i don't really know what you are asking. if you have a crx you would have to use an si tranny from another crx, and if you have a 5th gen civic you would have to use an si tranny from another 5th gen. crx trannies are cable clutch, 5th gen and newer are all hydro.
so if you are just using crx or 4th gen civic trannies then yes they will bolt up.
and if you are using 5th gen or newer civic's and trannies then those will bolt up.
but a 4th gen will not work with a 5th gen and vice versa.
ya i got a 1991 CRX DX, i lost first gear, so i g2 swap a new trans. in but would a 89-91 CRX SI trans. bolt right up clean??with no modification needed?
ok what about the axel, will my DX axel line right up to the SI transmission? and if it doesnt will the SI axel line up fo all my hub stuf? like my breaks? and other stuff on the end of the axel?
if you have your hands on all the si stuff, just use it cause ithink they came with bigger brakes anyway. and i think the hubs are bigger so if you ever went b-series it would be one less thing to worry about. not sure tho.
so what if i just got the whole axel acembly? like the hub and breaks then i wouldnt have to worry bout anything right?
The DX and Si axles are interchangeable- the hubs are the same, the axle length is the same, and the inner mount for the axles is the same too. The only real difference between the CRX DX and CRX Si transmissions is the final drive ratio- everything else is the same.
thanks alot bro, do u know if the breaks are any bigger? and i have also heard of people swapin the tegie breaks over to CRX's. is that a good idea? do they go on strieght with no prob?
All the CRX front brakes are the same size. The Integra brakes require you to swap the knuckles and everything over, so it's not just a bolt-on affair with the discs and calipers. Some people claim that it throws your caster all out of whack, but I haven't seen proof of it.
