D series to K series
  • Thread starter Thread starter Endless
  • Views Views 826
Endless
Anyone swap a D series for K series engine and if so, how much work is it and what is required.............I know it going to b expensive ...............i just need to know what parts r required and the wiring the harness because i think that where the problem will b.
IMO too expensive to do it, Swap in a GSR and then slap turbo onto that, You'll be more than happy.
Noone on here has experiance with K Motors inparticular to my knowledge, But it has been done, I'd say go with google or try searching through honda tech good luck!!
Do it! The K series has tons of potential, in my opinion much more than the B series. First off what kind of car do you have? Second off have you looked at HASports website they have a few swap mount kits. You are going to need pretty much all the stuff you need for a B series swap plus a few other things to get the K running.
So you are going to need;
Motor
Tranny
Axels
ECU
Wire harness
Shift linkage
Ect.
