d15b vtec swap
  • Thread starter Thread starter EMFinite
EMFinite
i wanna do a swap on my 89 dx hatch.
the motor i plan on buying is a 92-95 d15b vtech with everything including the tranny, ecu and wiring harness..
will this engine fit into my hatch without any modifications? do i need to do any rewiring? do i need to a dpfi to mpfi conversion to get this to work? do i need a different ecu than the one that comes with the engine?
please let me know what i need to do for this swap..
thanks
You need the 88-91 motor mount, and 88-91 transmission with transmission mounts.
Yes, DPFI->MPFI is needed.
Yes, the ECU that comes with the engine should work(P28 or P08).
Chances are you won't be able to use the transmission though. 92-95=hydraulic transmission, 88-91=cable transmission.
i just did the D15B in my 91 Honda Civic Nice Motor I Think i Have A Extra Set of Motor Mounts Pm Me If You Need Them
thanks for the replies..
can someone point me to a good write up for this swap?
