Dead End Wire
  • Thread starter Thread starter ChrisSiR
  • Views Views 681
ChrisSiR
have an 88 Crx with B16a swap w/ pwo ecu, i just baught the car and noticed a wire that wasnt hooked up to anything, Orng/blu,anyways after doing some research i found that it is for a TDC sensor, does this need to be hooked up to something here?
i dont get a Chk Eng light for it
Thanks
Chris
it depends, is this car a DX by chance??? if it is a DX and a MPFI swap was done there should be a loose wire or 2 by the ecu, and an extra plug hanging in the engine bay...
also where is this wiring hanging??? is it in the engine bay??? do you see a spot to hook it up???
its an Si Car, with a b16a Swap out of an JDM SiR
i didnt see anywhere to hook it up.....
Chris
The car is a Dx with a MPFI swap......
The only wire i saw was coming off of the ECU.... no spot to hook it up
Chris
