raceinspiredrex
you can run whatever obd1 ecu you want, you just have to run the right basemap. basically, you're running a p28 ecu basemap on your p06 ecu. a basemap is just a stock map another ecu that you can run
if you look at the vacuum lines, you'll see it's very easy and not complicated at all. there's like 4 lines that need to be ran into 1 single line, just use the stock vacuum splitters that're already hooked up on your stock lines
i didn't run dowel pins at all. i couldn't find any information about them with this setup, and i tried them in every hole and none of them lined up for both the head and the block
