mini me swap....
WsMikio
Member
at the time i didnt have the cash to do a k swap or even b swap so i figured id mini me swap. skunk 2 almost everything, had the head surfaced and was about to put it all together when i ran into a video were a guy said he had surfaced the head but not the block and his car burned up alot of oil... what do yall think? i do appreciate it fellas happy holidays
Briansol
Admins
Admin
VIP
The head gasket between the layers should make stock or shaved irrelevant so long as it's flat.
Oil burning is probably bad rings
TurboMirage
That’s how you get ants
VIP
indeed, i would suspect burning coolant / compression long before burning oil if the sealing surface was bad.
